Old 08-05-2020, 04:38 PM
t walgamuth's Avatar
t walgamuth t walgamuth is offline
The way the chassis is designed it is pretty easy to get 5050 distribution. That is not the only issue with the large displacement engine. The engine braking with a limited slip will cause the car to lose traction on the rear which is no problem unless you need to steer while at it....and then you can find yourself facing the wrong direction in a blink.
