Old 08-09-2020, 05:18 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
What fuel pressure do you run?
Can you see the seat size stamped at the top of near the flats?
Although your water test can give you a little idea, it doesn't compare, since fuel has a different density (lighter), the float is displaced at a different height.
Also fuel will creep past a bad needle, and past a bad o-ring.
Gary
Gary
