Old 08-10-2020, 04:03 PM
patrickt patrickt is offline
Originally Posted by SBSerpent View Post
"then it means either your needle and seat is leaking or your floats are too high or the gas you are using is really $hitty and is percolating up and out through the boosters"
...or the O-ring on the N&S assembly may be leaking?
I experienced exactly what you described in your write-up but in my case, it was on a cold start (car hadn't been run in days), which takes the percolating gas factor out of the equation.
Yep, that too.
