Old 08-13-2020, 04:26 PM
DanEC's Avatar
DanEC DanEC is offline
If you have big shoulders and arms you may want to try to find one to sit in. The top of door does come in pretty tight on these cars. Some who have built FFR cars (and maybe others) have actually cut and removed a bit of the roll in at the top of the door to get more upper body room. ERA will adjust the pedal spacing at your request but there's no way around that it's not roomy down there. I wear a 13M and even with my pedals spaced as far apart as they will go - I wear a set of sneakers that the soles are cut narrow and don't stick out from the upper of the shoe. Other shoes seem to catch the side of the soles on the pedals. You may want to consider a quick disconnect steering wheel too. Patrickt is all-knowing on ERA quick disconnect steering wheels and custom adjustments for fit in the cockpit.
ERA 782 Running
