Old 08-15-2020, 05:56 AM
133bus 133bus is offline
Cobra Make, Engine: dd cobra,351w mild cam
I think that heat wrap would be your friend in that situation...I assume your concerned about what the heat will do to your footbox...my rear left header is only about 13mm from my alumunium footbox (LHD)..I have wrap on the header and a thin sheet of stick-on heat reflecting foil on the outside of the box where my foot is up against it for the throttle...only time it gets hot is in stoplight traffic...also I have wrap on the headers where they exit the body for the side pipes..they is only about 13mm clearance and have no problems at all...steve
