Thanks for that Tom - unfortunately my experience, using a brake calculator and upgrades to the front brakes both show that the rear is in fact way under-braked.
The Jag system is designed for a nose heavy weight distribution and much more forward weight transfer under heavy braking with the softer springs than the Cobra which also has significantly larger rear tyres than the front.. My Cobra has 45/55 rear biased weight distribution compared to the jags 55/45. The jag also weighs almost 50% more than the cobra..
An acquaintance of mine has put a pressure limiting valve on his Cobra to limit the pressure to the front brake so that additional pedal pressure will feed more pressure to the rear and he says it has improved the stopping ability of his car significantly and is still unable to lock his rear brakes because the standard rear caliper is too small for a Cobra. This is totally contrary to all all recommendations for the use of brake pressure limiting valves and Willwood would freak at this use, but does seem to work! He says it works well on both road and track
My calculations support his findings but, if I can't modify the MC I might well pull the pistons out of the rear caliper and cut it up to preserve the handbrake and fit a second front caliper from some car of suitable piston size and then fit a pressure regulator on the rear to limit lockup.
