Old 08-26-2020, 08:04 PM
powrby4d powrby4d is offline
Cobra Make, Engine: Shell Valley 428CJ with 427 Tunnel Port top side
Default How to adjust SVC door
The driver side door on my SVC 2005 kit hangs just a little low at the rear. If I lift it slightly as I close it then it clicks fine and is correctly aligned with the body. I have no idea where to start to fix this: adjusting the door on the hinges or the hinges on the body, and the assembly manual is no longer available. Can anyone tell me where the adjustment points are? I would expect that somewhere there are bolts in slotted holes that allow for adjustment. I’d really like to know where I should start to be able to rotate the rear of the door upwards to engage the latch before I start loosening anything and possibly make the alignment worse instead of better.
