Old 08-31-2020, 12:34 AM
CompClassics's Avatar
CompClassics CompClassics is offline
Cobra Make, Engine: SAI FIA, 289HP (5-bolt), 48IDA Webers
Neutral
Which brake package do you have on your Cobra, Girling, Baer or Willwood? As Tom had suggested there may be a master cylinder issue or maybe a pad issue. If you opted for the Girling brake package the problem is more than likely the pads, there are several compounds available now from EBC.
I have retrofitted a power brake booster to a 6000 Series Continuation Cobra Ibuilt for a client that had had double knee surgeries that was very happy with the brakes after the install. I have also supplied the same booster to other clients so they could retrofit their Cobras with positive results.
