Old 08-31-2020, 08:21 AM
krausewich krausewich is offline
Cobra Make, Engine: MidStates, 351C, 4spd, 9"
Send a message via AIM to krausewich
Hi Dominik,
Measuring to the undersides of the wheel arch lips, to the underside of the nose opening, and to the bottom edge of the trunk opening should put you pretty close to where you need to be. Make sure which Contemporary body you have as well, because I believe they changed their wheel flairs to wrap closer around the tires at some point.
Best of luck!!
Mike
"It's not about getting from point A to point B. It is the point"
-J. James
M. Krause
1.508.944.3368
