Old 08-31-2020, 01:51 PM
twobjshelbys's Avatar
twobjshelbys twobjshelbys is offline
Originally Posted by CSXBill View Post
I see the three black round fluid containers. They aren’t labeled, but I will open and see which one is different color than the other two.
It was built in 2004 in Vegas. I’m not sure if brakes have ever been serviced, so I’ll start by bleeding the system and putting new fluid in.
Yes, sorry, there are three.
They will likely have the same fluid. Or at least mine did. DOT 3 as I recall for both brakes and clutch. It sort of doesn't matter - if it hasn't been serviced all of them need changing. (No matter what the fluid is contributing to the problem). Not knowing the service history you should just change everything that runs. If it's liquid, change it.
Tony
CSX4005LA
