  #22 (permalink)
Old 08-31-2020, 02:22 PM
twobjshelbys's Avatar
twobjshelbys twobjshelbys is offline
Brake pads don't wear out because they've sat on the car. It's likely the pads that are there were never properly bedded... A good hot run would probably make a world of difference. Change the brake (and clutch, and coolant and rear end and ...) fluids and then bed the brakes you have. You've got nothing to lose and will probably save your self some money and time. I had to run mine because they squeaked and made grinding noises like gravel.
Tony
CSX4005LA
