Old 09-12-2020, 08:59 AM
Mattsvtcobra Mattsvtcobra is offline
Cobra Make, Engine: Backdraft #360
Originally Posted by NROTOXIN View Post
Without any symptoms, conditions stated all I can comment on are your springs. With a light car your advance rate should be pretty fast. This means at least two light blue springs to begin with. If you can get away with it meaning, you have stable timing at idle, you can try one light blue and one light silver.
Here is what I posted last (Holley 770 Questions) in my post that seems to start to narrow down something with the ignition. So I figured the best would be for someone that knows way more than me to look at the rotor/cap/pickup/etc to make sure everything seemed in line.
"So I thought I had it all worked out. 1st ride after some WD-40, the problem was gone and it drove as it should. 2nd ride, it was doing what it was doing before and bogging bad. I took the air cleaner off and repositioned it a bit because its always hit the top of the distrib (working on getting a small riser to get it off of there) as well as opened the cap and closed it and the car ran great on the 3rd run. But any ride after has been where the RPMs climb.
Say I buy lube and not just use WD-40, put the air cleaner on a riser... Is there something I'm missing here?
EDIT: Just got back from a quick ride and the RPM's are not falling or fall slowly. I've tested all throttle linkage while in the garage and everything seems free. While on the ride, I used my big toe and the one next to it to grab the side of the pedal and it seemed to make the RPMs come down like they should.
*The weird thing is that on the past 5 trips when it was running good or bad I noticed one thing. If I felt it was good and the RPMs fell quickly, the car would run really well and responsive with minimal low RPM bog. If I felt it was running not so well and the RPMs would hang, there would be quite a bit more bog at the lower 2k range when I floor it. The engine would run a little more rough it feels and is noticeable in the car. Also, the start up would be almost instant if it was going to run well, and it would take some cycles for it to fire up if it was going to have not a good of a run.*"
