Old 09-14-2020, 06:01 PM
PaulProe's Avatar
PaulProe PaulProe is offline
Cobra Make, Engine: Hurricane - FE
Kevin
1) the bolt size is 5/16-18 UNC. The holes are tapped .60" deep. You'll have to add the thickness of your adapter bosses (they are different) to come up with correct bolt length
2) Bolts are torqued to 12-15 ft.lbs
3) I prefer Permatex #2 but Right Stuff would also work
4) The hose threads are NPT (Tapered Pipe Thread) Teflon tape or other proper sealant for tapered pipe thread
Hope this helps
Paul
www.65shlb.com
www.prdcrrct.com
