Old 09-16-2020, 09:03 AM
patrickt patrickt is offline
Originally Posted by Bobcat View Post
Just curious whose air/oil separator you were using . The one that comes to mind that has a mesh in it is the Moroso unit . I would also be curious what baffle system you come up with .
If that was aimed at me, I do have the smaller of the Moroso separators, along with the ME Wagner adjustable PCV, and Blue Thunder valve covers baffled as shown below. I have no problems whatsoever with them, and they work beautifully, provided that I empty the separator every 500 to 700 miles. Any more than that and the separator fills up about half way (that's two ounces) and then I start getting oil sucked in to the engine. You can tell when that happens because there is a slight decrease in off-idle performance and hot idling along with an increase in exhaust smell.
