Old 09-16-2020, 03:06 PM
Bobcat Bobcat is offline
Thanks for both replies .... I also have the Wagner unit and Moroso separator . I took the Blue Thunder VC off as the baffles weren`t doing the job . I would go through about a half quart of oil in just over 100 miles . It wasn`t in the separator , just seemed to go right through the Moroso unit into the intake .
My BT covers are the plain shot peened competition ones and the baffles are what you have Patrick .
The big difference I see is that you ( Patrick ) have your Wagner unit mounted higher than mine as I just used the grommet they supplied . I suspect that if I did the same , the BTV baffles would be adequate for the rpm I turn ...redline is 6400.
It seems the big difference between the Jegs unit and Moroso is the filter media with the Moroso unit not being as restrictive .
So , thanks for the info .
