  #31 (permalink)
Old 09-17-2020, 09:20 PM
cycleguy55's Avatar
Originally Posted by SBSerpent View Post
What kit and what part number is recommended for a 351W pan that does NOT have the smooth rails and doesn't use the reinforcement rails?
This is what it says at https://www.fordracingparts.com/part/M-6674-351 (emphasis mine):
Precision laser cut steel rails help minimize the chance of oil pan leaks on 351W based small block Ford Engines. These reinforcement rails are designed to be used with flat flange oil pans and one-piece silicone rubber oil pan gasket (PN M-6710-A351). These reinforcement rails are used on all Ford Performance 427-460 CID 351W based small block Crate engines
I know what it says, but I have no reason to believe these wouldn't work on a pan that doesn't have smooth / flat rails. I did a bunch of Internet searching and couldn't find any other rails, so it's either these or nothing.
Again, don't use bolts, use studs and nuts. I went to a local bolt supply and purchased the appropriate length 'set screws' and flange nuts, and put the set screws in with blue Loctite.
Brian
