Old 09-20-2020, 05:47 PM
Moritz55's Avatar
Moritz55 Moritz55 is offline
Cobra Make, Engine: Superformance, '65 427/MKIII with Roush V8 - 351W w/770cfm 4BBL Holley, 514hp
Originally Posted by S1965C View Post
Realizing all engines are different, would still love to learn more about your setup. Things like carb jetting, power valve, initial/full dist. advance (including springs used), ignition source/type (i.e. MSD 6AL), trans OD ratio and rear end gearing, etc. I have a similar motor with a 750 Mighty Demon and I get 10mpg on a good day.
Here's what I have the Roush 427SR (351w) tuned with:
- 93 Oct fuel*, TKO600 5spd, 8.8" Rear End with 3.73:1 ratio.
- Annually I check the Carb Bolt down and torque to spec, 60-80in-lbs(5-7ft-lbs). When i first got the car 3 bolts were extremely loose and vacuum had leak when cold.
- Annually check Disty Cap & Rotor, replace them every 2 (maybe 3) years. MSD HiOutput/6AL puts a lot of wear & tear on them.
- Annually I run a can of Seafoam through a tank full... living in NC I can drive it year round so no need to winterize it but still do this on all my classic sports cars. I have added 2200miles on it since April 2020 when I bought the car.
- Have a MSD Hi-output Coil, MSD 6AL box, use cooler NGK BKR6E-11 Plugs , gapped at 0.045" (between .042"-045" works best).. Note: Roush specs using Autolite AR3923, heat range 3 plugs so the NGK's I use are equivalent with their heat range of number 6.
- Have a Mallory #8578 Pro-Billet Disty, Mechanical advance .. with 2 Silver (lighter) springs.
- Idle Set at 920rpm and Timing @ 15.5 BTDC ... at 4000 rpm, Timing @ 32.5 BTDC (Roush spec is 31-34 BTDC, must be LESS than 35 BTDC).
- Have a 770 Holley QF (80770-1) ... don't know exactly the jetting, nor power valve as it came from Roush as a crate engine ... sorry here...
- Currently have BOTH A/F Carb Mixture screws set at 1-1/2 turns OUT (I don't have 4 corner A/F mixture screws... just the 2 front ones). Here I spent a lot of time tweaking with 1/8 turn increments to find the sweat spot... when I bought the car in April 2020, the car came with A/F turned 1-3/4 out (on passenger side and 1-5/8 out on the driver side) so I reset them to starting at 1-1/2turns out as the documentation suggests and ended up here anyway.
.... When I bought the car , it's Idle timing was @ 10.5 BTDC... Disty Cap & Rotor were shot, Autolite plugs gapped .052"-.056" .. and I know I had vacuum leaks with the Carb Bolts looser than spec when cold. I was getting 10-11mpg at best....
NOTE: * I use regular 93 Octane even if it has some ethanol , so I tuned the engine with this type of gas..
Hope this helps and feel free to PM me for more discussion...
Many thanks,
Mark
Superformance: SPO2454 , Titanium w/Black Stripes
Engine: Roush 427SR w/770cfm 4-Barrel Holley
Transmission: Tremec TKO-600
