Old 09-23-2020, 08:34 PM
powrby4d powrby4d is offline
Cobra Make, Engine: Shell Valley 428CJ with 427 Tunnel Port top side
Default How to access 2005 shell valley pedal box?
Hi, as said in the title. I have to do some work on the clutch and brake setup and I can’t see any kind of opening or removable panel for accessing the pedal assembly from inside the car, inside the engine compartment, or from the side. Shell Valley doesn’t have any of their assembly manuals (?) so I can’t see how it went together in the first place which might tell me how to access it after the fact. All the metal areas in front of the steering column have bolts in them but appear to be bonded to the body, as the side vent appears to be as well. Hard to tell on the assembled car without removing a lot of stuff that might get me nowhere. Any insights into the secret access panel would be helpful so I don’t end up taking a cutting wheel the most likely spots for lack of any other solution. Anyone with an assembly manual for the SVC 2005 Cobra I would appreciate any guidance.
