Old 09-28-2020, 08:33 AM
bobcowan's Avatar
bobcowan bobcowan is online now
Default Steering Squeak Fix
Lately, my car has developed this really annoying squeak whenever you turn the steering wheel. Sounds like rubber on metal. Drives me nuts! I tried adding lube here and there. Even trimmed down the plastic shroud and removed the horn connections. Nothing seemed to fix it. Yesterday I removed the column to find it.
The central steering shaft rides on two aluminum bushings pressed on to each end. The steering wheel end also has a plastic bit covering the bushing. I pulled the front bushing out a little and lubed both of them with some high pressure wheel bearings grease.
Then I found the real problem. Just behind the dash, this is what secures the steering column to the car.
Pretty simple assembly. A muffler clamp with a plastic bushing.
Here's the real problem, and the cause of the squeaking.
I considered calling on Monday and ordering another one. Might as well order two, because in another 10K miles I'll be doing this job again.
Then I decided on a permanent fix. Started out with a small piece of billit aluminum.
Drilled a couple of holes through the edge
And cut a 1 1/4" hole in the middle.
Then cut the whole thing in half with a hack saw.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
