Old 09-30-2020, 09:11 AM
Grey 65's Avatar
Grey 65 Grey 65 is offline
Cobra Make, Engine: BDR #888, Keith Craft 408
Originally Posted by SBSerpent View Post
How much oil do you put in when you do an oil change? Trying to figure that out because the Aviaid website says that the 55363 pan is the 55361 6qt GT-40 pan but without the notch in the sump to accommodate the larger starter on the GT-40. As such, the Daytona Coupe pan (55363) can hold an additional half quart, bringing the sump capacity to 6 1/2 quarts. Running the WIX 51515 filter (the larger sized filter) will add another half quart(?). So, this comes out to about '7ish' quarts at each oil change? Just trying to figure out the total capacity.
To be honest I am not sure it is between 7.0 and 8.0. Before I installed the pan I had to cut the dipstick since it a universal length. So I mounted the dipstick to the pan cutting as required. Then I filled pan with water and marked dipstick for low and high. I then drained the pan, dried the pan and then installed on the motor.
Kevin......
It isn't how fast your car can go
It is how fast your car can change direction
Home of Fake Snake Racing
