Old 10-01-2020, 07:01 PM
PaulProe's Avatar
PaulProe PaulProe is offline
Cobra Make, Engine: Hurricane - FE
Originally Posted by bwcobra15 View Post
. . . other sizes available are .700 and .625 bore. So can I go down to move more fluid to the Tilton HTOB.
Bobby
Going down is going the wrong direction. The smaller puck will move LESS fluid with the same amount of movement.
According to the Tilton installation page (https://tiltonracing.com/wp-content/...ies-HRB-V2.pdf) According to their page, 3/4" would work if you get about 1.3" of cylinder movement. Which I suspect you are not, especially since you lengthened the pedal. You probably should be looking at a 13/16" cylinder and figuring out how to modify your pedal lengths and stops so you are getting 1-1/4" of cylinder puck movement.
Paul
www.65shlb.com
www.prdcrrct.com
