Old 10-06-2020, 03:44 PM
davids2toys's Avatar
davids2toys davids2toys is offline
Cobra Make, Engine: ERA, 428, 4 speed Toploader, Jag rear, Red with White stripes
Great idea, I did this minus driving around like that hooked up. I only have the light with the probe so how would you hook that up. i went looking on line for a type of test light with 2 clip ends on it instead of the probe, but I do not see anything like that. i suppose I could maybe make a wire with a terminal end on one side and fasten it to the IGN terminal of the switch and tape the other end securely to the probe, then hang it from the glove compartment somehow.
I also tried jiggling the key like crazy with the ignition on and the dashboard amber light lit, could not get the light to blink at all. I should try to probe the small red wire going from the switch to the MSD box and then wiggle the wire near the switch to look for a bad terminal connection
ERA#698 428, 4 speed Toploader, 3:31 Jag rear
