  #21 (permalink)
Old 10-06-2020, 05:45 PM
PaulProe's Avatar
PaulProe PaulProe is offline
Cobra Make, Engine: Hurricane - FE
Originally Posted by bwcobra15 View Post
. . .at rest it shows about 1-3/4", and with the pedal fully depressed it shows 2-3/8" - for a total movement of about 5/8" (0.625"). . .
Bobby
Look at your initial reading again. I am seeing 1-15/16" for a total throw of a little less than 1/2"
That is a little shorter than what you'd like and if you get a little sloppy and don't push the pedal all the way down (Don't ask how I know about this) then the stroke gets to be a touch too little, the disk still spins, the gears grind or shift hard.
Having just a touch more won't hurt anything and will make it a little more user friendly.
I still think your issue is in the stroke of the master cylinder. Bet you're not getting as much throw as you think you are. Back the clevis off a little on the master cylinder pushrod - which will raise the pedal slightly and give it a try.
Say Hi to the Hurricane guys
Paul
www.65shlb.com
www.prdcrrct.com
