Old 10-16-2020, 10:05 AM
eschaider's Avatar
I do not believe SPF ever offered a six pin hub for their cars that I recall, Tommy. Additionally unless the wheels were made for the pin drive spinner retained methodology used by SPF he would have to do some modifications to the wheel hubs.
I suspect, but do not know with certainty, that when you remove the pin drive lug nuts you will need to replace the SPF provided studs with conventional wheel studs to retain the wheels. Of course if he has found a set of pin drive Torq Thrust's (does such a wheel exist?) the conversion is simpler.
Ed
