Old 10-21-2020, 02:41 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by SBSerpent View Post
Also, in which direction is the coolant flow on a CW rotation w/p? From passenger side head to drivers side head or vice versa?
No V8 goes from one head to the other.
The path is lower radiator hose to water pump inlet, pump outlets to each side of cylinder block, through each side of block, through rear of block up to rear of cylinder head, back through cylinder head from rear to front, exit both heads to intake manifold, thermostat housing, top hose, radiator, lower hose.
Gary
