Old 10-21-2020, 04:17 PM
SBSerpent's Avatar
SBSerpent SBSerpent is offline
Cobra Make, Engine: BDR build #983, FRM 392
Originally Posted by Gaz64 View Post
No V8 goes from one head to the other.
The path is lower radiator hose to water pump inlet, pump outlets to each side of cylinder block, through each side of block, through rear of block up to rear of cylinder head, back through cylinder from rear to front, exit both heads to intake manifold, thermostat housing, top hose, radiator, lower hose.
Yes, of course. Not sure as to what I was thinking.
So there is really no reason to suspect that going from the w/p inlet to the outlets that there would be a pressure differential between left side or right side entries into the block.
