Old 10-24-2020, 01:06 PM
Mark IV Mark IV is offline
Senile Club Cobra Member
Originally Posted by tortuga View Post
Ground in lh wheel well and under dash look good...
Kind of suspect relay; on the switch there is a red wire which shows system volts, ablue that should turn on headlights, and a grey/black that is for gauges and running lights? Shorting the hot to either of these does nothing...well actually writing this, if the relay was bad the gauges and running (marker and tails) should come on?
Sure seems like a ground...
Where does the lighting system ground?
Thanks
Steve H
1764
You need the wire diagrams from Blas, all will revealed! spfwiringdiagrams@comcast.net
rick@autoventureusa.net
