Old 10-30-2020, 06:11 PM
twobjshelbys's Avatar
twobjshelbys twobjshelbys is offline
Originally Posted by Steve Gallegos View Post
Update on fuel pump, check pump for current, no current going to it, checked relay cradle 12 volts coming into it, Relay itself checks out conductance ok. My next idea is to run a line from my battery to the + side and see if it runs. If it does, don't know what to do next.
Check the load side of the relay at the relay using a DVM (or an analog volt meter if you're that old - I am, my 45 year old Radio Shack volt/ohm/amp meter works just fine and I've never felt compelled to upgrade). Then also run a jumper from the output side of the relay directly to the pump.
Tony
CSX4005LA
