Old 06-15-2002, 01:30 PM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
Make your own bracket out of mild steel to bolt the lever to. The lever only has one cable, but that will need to pull on a " T " bracket to which two cables are attached, one per rear wheel. (Unless you have a pinion mounted e-brake) At the " T " bracket, there will need to be another bracket welded to the frame to hold the cable sheaths for the cables which will run out to the calipers. Depending on what type of rear end and brake calipers (or drums) the cable mounting at the wheels will be factory supplied hopefully, as long as you use the correct style of cable assembly.
