Old 06-15-2002, 12:36 PM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
I've replaced throttle body efi with Holley 4bbls before, finding more power and throttle response in the process. You have a 462cid big block, it will never sip gas even with a really good b.s.f.c. but you should be able to get 10 -12 mpg on the highway if you have overdrive. That motor sounds like it would like an 850 double pumper more that a 750 vac sec.
