Old 11-03-2020, 11:10 PM
olddog olddog is offline
Originally Posted by SBSerpent View Post
One thing that I should note is that just prior to this occurrence, I had adjusted the clevis on the master cylinder plunger rod to where it connects to the clutch pedal - bringing the pedal closer to the firewall. I will re-adjust it back to where it was before this issue popped up and see if that resolves the problem.
Have you corrected the pedal adjustment yet?
You have shortened the stroke of the pedal. Most likely you no longer have enough stroke to fully disengage the clutch.
It isn't rocket science. You changed the stroke of the clutch pedal and just after that the problem showed up out of the blue. What's the odds that some other random thing just happened to happen at the same time and caused your problem????
Don't take this wrong, but.... Hey it's your time and dime so go ahead and change as many other things as you wish. I suggest trying at least a dozen other things. That always makes the troubleshooting so much easier, when you goof up a couple more items and make the problem worse.... Sometimes when you look at it from an extreme position, it makes the point much clearer.
Good Luck
