Old 11-16-2020, 06:13 AM
Dwight's Avatar
Dwight Dwight is offline
Smile
You better check the Blue Print motor before you beat on it.
We pulled a 347 Blue Print motor out of Ron's '65 Mustang last week. He bought the Mustang a year ago and put 5,000 miles on it. The second time he wound it up through the gears to third a piston came apart.
We tore the motor apart last Friday and Saturday. We found the cheapest parts they could use to build a motor. Hypereutectic pistons without enough ring gap is what probably broke the piston.
This motor would be find in a daily driver but we don't think it will hold up to any hot rodding. This one broke the second time with a little spirited driving.
The motor was bought from Jegs and has a serial number but they could not tell us anything about the parts in it.
The shop that build the car installed a MSD distributor with a steel gear and the long block had a cast cam. LOTs of wear on the cam gear.
He is ordering a 331 from Lance at Craft Performance today.
I have a motor for sale, minus one piston, rings, cam. Carb to oil pan and flywheel. cheap.
