Old 11-30-2020, 03:29 AM
xb-60's Avatar
xb-60 xb-60 is offline
....am going to upgrade the clutch and flywheel and refresh the engine since I had to pull it to get at the clutch....
Jim, your flywheel and clutch requirements would be way different to mine, however I'm about to spec a flywheel, clutch and HTOB, so I'm interested in what you will be using. Your gearbox is a Toploader and so is mine so there's commonality there. So too with the Quicktime scattershield, but the only other 'hardpoint' is that I will probably need to use an HTOB because of tunnel size limitations.
Cheers!
Glen
