Old 12-01-2020, 09:47 AM
eschaider's Avatar
Originally Posted by MKS427 View Post
... If I could get a 2.90-2.80 rear gear (not available for the 8.8 Ford), I would and switch to the .82 OD. ...
My 2.73 gear is an OEM Ford gear for their 8.8 like used in T-Birds and Mk VIII's. They also have 2.92 and 3.08 available and if you go to the aftermarket I believe there are 3.00 and 2.90 ratios available. The 3.00and 2.90 are not hunting gear sets. If you select a new gear set you should look for a ratio that is a hunting ratio. It will run quieter.
Ed
