Old 12-01-2020, 05:08 PM
MKS427's Avatar
MKS427 MKS427 is offline
Cobra Make, Engine: FFR MkIV 427
Originally Posted by eschaider View Post
My 2.73 gear is an OEM Ford gear for their 8.8 like used in T-Birds and Mk VIII's. They also have 2.92 and 3.08 available and if you go to the aftermarket I believe there are 3.00 and 2.90 ratios available. The 3.00and 2.90 are not hunting gear sets. If you select a new gear set you should look for a ratio that is a hunting ratio. It will run quieter.
Ed
I have an 8.8 solid axle. Do you know of gears below 3.08 for it? I couldn't find any. I have a FFR and am considering swapping to IRS. I may have a choice between T-Bird and Mk VIII or '15 and newer Mustang. Any thoughts on the two? 3.08 and bigger is all I've found for the current platform.
Thanks,
Mark
