Old 12-02-2020, 10:41 PM
Bender Bender is offline
Cobra Make, Engine: G Force Cobra 347 stroker
Slowy, You can get most of the bearings and seals from most reputable bearing shops. I use Pine rivers bearings in Brendale QLD for my bearings. The guys are old school and very knowledgeable. Just take down your old bearings and seals for cross referencing. The pinion spacer and side shims you can get from Jagdaim. I had the gears for a Hot rod diff lapped by Diff Lapping QLD. Lapping will reduce the noise if the gears were not correctly matched. Hope the info helps.
Bender
