Old 12-07-2020, 12:49 AM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by eschaider View Post
And if you look at the transmission internals they are very nicely done with fully machined countershafts and corresponding splined gears along with an attractive selection of gears to choose from so you can get multiple gear selections to choose from to suit your personal tastes.
Richmond used to put the center to center distance on their engineering drawings they published on their site but I could not find it on the current drawings. Using the information from the drawings they do publish it can be calculated and it appears to be a 91mm center to center distance compared to the TKO's generous but smaller 83mm center to center distance for the main and countershafts. Very nice transmission and very nice Long shifter.
FWIW, the tail shaft mount location iis different than a TKO. According to mfg published specs, the TKO tail shaft mount is 15.49" from the bell housing face and the Richmond is 18" from the bell housing face so there may be a little massaging required one to the other.
The other slight difference is the bell housing face to end of tail shaft. The TKO measures 23.8 inches and the Richmond comes in at 24.0 inches — likely no driveshaft mods required. Net net bottom line a nice alternative to a TKO.
Ed
Only 1st gear has one of 3 optional ratios.
Very nice trans, I would have one for next car.
Gary
