Old 12-13-2020, 07:17 AM
Scotchman's Avatar
Scotchman Scotchman is offline
Cobra Make, Engine: FFR MK3/302/570 street avenger
Default Clutch pedal sleeve needs thicker washer
Now that I've replaced the clutch pedal sleeve, I've noticed quite a bit of play from side to side. The pic is showing the old sleeve, and it looks tight. Getting the old washers in was a *****. I don't know if I can get a thicker washer in.
The existing washers are brass, I believe, and very thin.
Anyone have a recommendation on a new washer, and is there a trick for installation ?
