  #125 (permalink)
Old 12-14-2020, 02:18 PM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
Originally Posted by eschaider View Post
Bottom line, I think the 5th gear overdrive design was never intended for use in a power-shifted environment. Just not power-shifting into 5th overdrive might be the easiest and most straight forward fix for the problem. Moreover, if you haven't won the contest before 5th gear overdrive, I am not persuaded that 5th gear will make a difference in the outcome anyhow.
Ed
Well, from reading some of the posts, maybe it's not powershifting into 5th, so much as "power" shifting from 2nd to 3rd, and somehow hitting 5th gear instead, putting stress on the 5th gear shaft ?
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
