Old 12-24-2020, 11:42 AM
MAStuart MAStuart is offline
My 1964 Mickey Thompson catalog lists stroker cranks for 289's.
Jim did your engine builder put the scare on you to upgrade? Depending on your tune you would be fine up into the lower 500 Hp range. Now if you were going 24 hour racing.....get a better block. I have an Jan 67 hotrod artical on the gurney eagle engines. Dan said that they had made as much as 448Hp with 271 HP cast iron heads on a 325 inch engine. So they were making them big before 67! Also the big numbers were 506 HP from a 289 with the gurney eagle heads on gas with webers. So they were making big number way back before 67.
How did your engine look wheen they took it apart? Any problems? There is a guy out east that has a progam to cnc port 289 heads that guys have been making in the 425 to 450 range with. I think they are also remaking the C6FE heads and cnc porting them. There is nothing like a real 289 making big power. I really like them when they use a factory 289 block ,heads and crank. Yes with aftermarket blocks and heads and cranks they might make a little more power. But I dont think they are as cool.
