Old 12-27-2020, 09:29 AM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
Originally Posted by olddog View Post
I might add a hydraulic lifter acts as a dampener to reduce the shockwave of metal hitting metal. I think the oil pressure in the hydraulic lifter holds the lifter in contact with the cam, but I'm not certain of that.
Yes, that is because the lifter is in constant contact with the lobe of the cam, and lash is always at zero. I think the contour of the cam, after the lobe, is different between solid and hydraulic cams. Hydraulic lifters have spring loaded plungers with the added effect of the oil pressure to keep the lifter in constant contact with the camshaft.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
