Old 12-29-2020, 07:49 AM
blykins blykins is offline
The thing about camshafts is that cam companies spit them out and most guys are happy with them because they have never tried anything else.
I've been testing and dyno'ing camshafts in Fords for quite a while, back-to-back, many times doing cam swaps the same day on the dyno.
Here's a couple of scenarios, tell me how much hp you think is different between the two camshafts, given that all other engine specs are exactly the same:
Scenario 1, 445 ci Ford FE:
Camshaft 1: 286/294, 231/239 @ .050", 114 LSA, 108 ICL, .630"
Camshaft 2: 286/290, 231/235 @ .050", 113 LSA, 108 ICL, .630"
(If you'll notice, the overlap is exactly the same on these two cams)
Scenario 2, 354 ci Ford Cleveland
Camshaft 1: 289/297, 259/267 @ .050", 108 LSA, 106 ICL, .700"/.660"
Camshaft 2: 287/315, 257/277 @ .050", 112 LSA, 108 ICL, .700"/.700"
(Overlap the same on these two cams as well)
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
