Old 12-29-2020, 10:08 AM
MOTORHEAD's Avatar
MOTORHEAD MOTORHEAD is offline
Cobra Make, Engine: KIRKHAM 427 S/C, SHELBY 427 ALUM. STROKER
Default Htob
My car was built in 1998 with a Mc leod bolt on htob. On the top loader it takes the place of the front bearing cover and t.o. bearing slide tube. It had some corrosion on the piston, so I elected to go with external hydraulic slave. Had to find an original nose piece, and Mcleod provided a "modified" pressure plate ( the diaphram fingers were cut back for clearance as the std tob tube was larger diameter than the HTOB TOB set-up was.
That set-up was never good, cutting the fingers looses about 20% of the leverage of the fingers, and the cuts on the fingers leaves a sharp edge that cut into the bearing face and causes the system to "hang-up" So I have decided to see if I can get the HTOB to work and be reliable. Right noe my problem is one of the hose connections ( banjo fittings) leaks. ( this is an older set up with banjos, not swivel fittings.)
More later
Tedl
"When Injustice becomes Law,
Rebellion becomes Duty." T. Jefferson
