Old 01-01-2021, 08:04 PM
patrickt patrickt is offline
Unless you're going drag racing with really sticky tires, or you're going to repeatedly strap your car down to the chassis dyno so it can't break traction, I don't think it really matters on a mostly street driven car that only has 600 lbs on each rear wheel. My crappy Yokos break loose if I give it any sort of throttle, like maybe 200 ft/lbs or less of throttle. I think a cardboard driven disk and a pressure plate made of bobby pins would hold it all together and the tires just break loose when the torque gets cranking.
