Old 01-10-2021, 07:53 PM
cycleguy55's Avatar
Originally Posted by Mongoose930 View Post
They make plenty of high current toggle switches so you might be able to skip the relay. This one is rated at 25A and is sealed:
https://www.ckswitches.com/media/2301/pt.pdf
Going with my current plan:
  1. I much prefer using relays rather than switches for higher currents.
  2. I already have a set of matching switches, as well as a handful of relays.
  3. I can wire the relay to feed both low beam and high beam. One terminal is low beam and another is high beam. The toggle switch merely flips the relay between the two.
Brian
