Old 01-11-2021, 11:50 AM
cycleguy55's Avatar
Originally Posted by Gus M View Post
I was driving today and applied the clutch only to have the driver's seat slider give way and fully retract backwards. The driver's seat slider will no longer latch into a position that I need without retracting when applying the clutch.
At 5'9", 170 lbs, that's a problem in reaching the pedals with the drivers seat all the way back. A new slider has been requested from Backdraft.
Has anyone replaced a slide? Is is difficult to remove the seat? Any input as to a better slide for the driver's seat as an alternative?
Any applicable input is appreciated.
Thanks
Gus
Is it possible the lever return spring has just broken or slipped out? Does the slider need to be replaced, or just removed, inspected, cleaned and re-installed? I would think sliders are pretty reliable, so I'd bet on the latter.
Brian
