Old 01-11-2021, 07:28 PM
Gus M's Avatar
Gus M Gus M is offline
Cobra Make, Engine: BDR Iconic 427 (Dart SHP-Ford 351W)
Originally Posted by cycleguy55 View Post
Is it possible the lever return spring has just broken or slipped out? Does the slider need to be replaced, or just removed, inspected, cleaned and re-installed? I would think sliders are pretty reliable, so I'd bet on the latter.
I can see that the "teeth' are engaging into the slide but when applying the clutch, that force pushing back into your body is enough to have the teeth pop out of the slide and the seat goes flying back. Could that be a spring issue?
