Old 01-11-2021, 10:03 PM
Gus M's Avatar
Gus M Gus M is offline
Cobra Make, Engine: BDR Iconic 427 (Dart SHP-Ford 351W)
Originally Posted by Cashburn View Post
Put the seat where you want it and then swap out 2 of the mounting bolts for a bit longer bolt. It will lock it in that setting.
Thanks. It's an option if all else fails. I like using the slide to get in and out. Makes it easier when you drive closer to the wheel to get out, hence, I use the slide every time I use the car.
I think what's really needed is a two slide rail system as you have in your everyday car. Waiting for the new slide and we'll see what happens.
