Old 01-16-2021, 05:28 AM
blykins blykins is offline
Originally Posted by daverascal View Post
I have a 408 Winsor in my car. I had planned on a BBF but my engine builder talked me out of it. He said the hp to weight ratio isn't there unless you build a mountain motor. My only advice is to use best internal parts you can buy. My only regret on my build, I used a Ford block and I'm at the limit of the block. I have main stud girdle and arp studs everyplace. If i could do it over I would have used a dart block.
Girdles don't do anything, unfortunately. Lots of nice photos of SBF blocks split in half with the girdle holding the main caps together.
The 302/5.0 block won't take as much horsepower before letting go, but unless you're making over 600 hp with that 408, you're in no danger of hurting it.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
