  #35 (permalink)
Old 01-20-2021, 06:34 AM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
cool engine build !!!
he stated the engine was built to be a blower motor, with appropriate heads, cam, compression (12.5), and made 790 HP. he thought that if he were to built it to be a NA engine, with ? 16:1 compression, different heads, cam, and dry sump, vacuum pump, bigger throttle body, it would make closer to 900 HP.
when he installed the supercharger, he also installed a dry sump , and ran the boost at 16.5 psi. he never mentioned the difference in air supply temperature.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
